Applicable Model
This information is for the following model(s):
  • ILCE-7M5
About This Download
What to Keep in Mind Before Performing the Update
  • If you are updating from Ver. 1.00, please follow these steps before starting the update:
    1. Set the Wi-Fi Connect setting to Off.
    2. Set the Cnct. while Power OFF setting to Off.
    3. Turn off the camera.
    4. Remove the battery, then reinsert it.
  • You can download the software update using the Creators' App available in the App Store and Google Play.
Benefits and Improvements
  • Allows high-quality audio recording (96 kHz, 32-bit float) when the XLR-A4 adapter (sold separately) is attached to the Multi Interface Shoe
  • Adds support for the Preset Focus function with lenses that do not have power zoom
  • Supports displaying the focal length down to one decimal place
  • Allows simultaneous Delete and Rating of images recorded on both memory card slot 1 and slot 2
  • Allows the display of folder names and file names during playback
  • Allows you to cancel the scheduled transfer of selected images during FTP* transfer
    *FTP = File Transfer Protocol
  • Adds support for the following Transfer & Tagging settings:
    • A setting to automatically schedule FTP transfer of protected still images from FTP Import
    • A setting to automatically schedule FTP transfer of protected still images and videos from FTP Upload Preset
    • A setting to automatically protect still images transferred via FTP from FTP Upload Preset
    • A setting for configuring the SFTP (Secure File Transfer Protocol) server
      • The latest version of the Transfer & Tagging setting is necessary.
        Note:  The Transfer & Tagging setting may not be available in some countries or regions.
  • Supports the Write Digital Signature function for movies as part of Sony’s Camera Authenticity Solution
    • The timing for the provision of licenses (paid) to customers other than certain media outlets is yet to be determined.
    • Services may not be available in some countries or regions. For more information, please visit the Authenticity Catalog Page.
  • Supports Scan and Tag, Photo Cropping, and Volume Photography Commands under the Volume Photography License
    • Installation of a paid license is required for use.
    • The license is scheduled to become available from late May 2026 onwards.
      Note:  Services may not be available in some countries or regions.
  • Ends support for updating the lens firmware via the menu using a memory card
    Note:  Please use the Windows/Mac OS software update tool to update the lens firmware.
  • Fixes an issue where recording may not be possible when shooting movies with the ECM-M1 (sold separately) attached
  • Improves the operational stability of the camera
Notes:
  • If you are using the Camera Remote SDK (Software Development Kit), please check the Camera Remote SDKwebsite for a list of supported devices, download instructions, and FAQs.
    Note:  The Camera Remote SDK may be unavailable in some countries or regions.
  • Please refer to the Help Guidefor details on all updated functions.
File Info
  • Name: BODYDATA.DAT
  • Version: 2.00
  • Size: 376 540 720 bytes
  • Release Date: 14-05-2026
Preparation
How to Update Your Sony Camera With a Memory Card (SD or CFexpress)
If you are updating from Ver. 1.01, please follow these steps before starting the update.
  1. Set the Cnct. while Power OFF setting to Off.
  2. Set the Wi-Fi Connect setting to Off.
You are now ready to perform the update.
Check the System Software Version
Follow the instructions below to check the system software version:
  1. Select MenuSetupSetup OptionVersion Body.
  2. The system software version will be displayed.
Notes:
  • If the system software version is Ver. 2.00, the update is not required.
  • If the Date /Time setting screen appears when you turn on your camera, set the date and/or time to the correct values.
Saving the System Software Data to a Memory Card
IMPORTANT: Make sure there is only one BODYDATA.DAT file on the memory card.
To save the system software data to a memory card:
    1. Click the Download button.
    2. After reading the disclaimer, click Download.
    3. Save the file to your computer.
    4. Insert the formatted memory card into the computer.
    5. Save the BODYDATA.DAT file in the root directory of the memory card. Do not change the file name.
    Notes:
    • Please use this camera to format the memory card in advance.
    • Before formatting, copy the data to a computer or other device.
      • After formatting, the data on the memory card will be permanently deleted and cannot be restored.
    • Please refer to the instruction manual of the camera for compatible memory cards.
    Power Requirements
    • Power source: Use a fully charged rechargeable battery pack (NP-FZ100).
    • The update can only be performed when the battery power level is 51% or higher. We recommend you use a fully charged battery.
    Hardware Requirements
    • Detach the vertical grip from the camera before updating the system software .
    Updating the System Software Version
    Important Notice
    • Use a fully charged rechargeable battery pack (NP-FZ100).
    • Do not remove the battery during the update. Doing so may cause the camera to become inoperable.
    • It may not be possible to update if the camera temperature is high. Please wait until the temperature drops before updating.
    Step 1: Update the System Software
    1. Insert the memory card that contains the saved system software data into slot 1 of the camera. Only slot 1 will recognize the system software data.
    2. Select MenuSetupSetup OptionVersionBody.
    3. Select Software Update.
    4. Select Execute on the system software update confirmation screen. The software version update will start.
      On-screen message:
      • Update? X.XX → Y.YY
        • X.XX: Current version number
        • Y.YY: Newest version number
      Notes:
      • Do not remove the battery or memory card during the update.
      • After confirming the details, click the Execute button.
      • Scroll down as needed to view the full text.
    5. When the system software update starts, the elapsed time and update progress will appear. The access lamp will then flash 1 time3 times5 times depending on the progress. The update will take approximately 6 minutes to complete.
      Location of the Access lamp: It's on the bottom right of Rear side.
    6. When the update is complete, the camera will automatically restart. After restarting, press OK on the “Body update complete” screen.
    Step 2: Confirm the System Software Version of Your Camera
    1. Select MenuSetupSetup OptionVersionBody.
      The update was successful if the screen shows Ver. 2.00.
    If the Update Fails
    If the system software was not copied correctly to the memory card, the camera may display an error message or signal an error using the access lamp.
    What You May See:
    • The message “The target model for the update file is incorrect” appears on the camera monitor.
    • The access lamp blinks in one of the following patterns:
      • 5 long blinks (0.5-second cycle) followed by 6 short blinks (0.25-second cycle)
      • 7 long blinks (0.5-second cycle) followed by 7 short blinks (0.25-second cycle)
    What This Means:
    • The system software may have been copied incorrectly to the memory card.
    What to Do:
    1. Remove the battery and memory card from the camera.
    2. Prepare another memory card.
    3. Start again from the Saving the System Software Data to a Memory Card section of this article.
