Article ID : 00119381 / Last Modified : 30/03/2021Print
    Which lenses can be used with my camera?
    Compatible lenses for the interchangeable lens cameras
    For a full list of compatible lenses for your camera, we recommend to use the interactive tool for full compatibility information.
    On this website you can cross-reference cameras with different type of lenses and learn if there are any restrictions in usage, or if everything is fully compatible.
    To navigate the interactive tool:
    1. Select your camera model from the list.
      • Under E-Mount you will find ILCE and NEX models.
      • Under A-Mount you will find DSLR, ILCA and SLT models.
        • If you do not know the model name of your camera,  click here to learn where it can be found.
    2. Once you have selected your model you will see all of Sony's and Konica Minolta's lenses that are compatible with your camera.
