Article ID : 00092967 / Last Modified : 03/12/2014Print
    Are there any lenses that do not support AF Micro Adjustment?
    All Sony A-mount lenses (SAL) support the AF Micro Adjustment function.
    Minolta and Konica Minolta AF lenses are also supported, however you cannot individually perform AF fine adjustment when using the Sony, Minolta, and Konica Minolta lenses that have the same specifications.
    Minolta AF lenses will also work when used with a 1.4x or 2x teleconverter APO, APO-II or APO-D. However, the adjustment value may not be registered with the following Minolta lenses:
    • AF APO 200/2.8
    • AF APO 300/2.8
    • AF APO 600/4
    If you perform AF fine adjustment with a lens of other manufacturers, the adjustment values of Sony, Minolta, and Konica Minolta lenses may be affected. Therefore it is not recommended to use this function with any lens of other manufacturers.
