With the Imaging Edge Mobile app, you can access different camera settings and control your Sony camera remotely from your smartphone.
Note: The Imaging Edge Mobile app replaces PlayMemories Mobile™.
IMPORTANT:
To perform this procedure, you must install the Imaging Edge Mobile app on your smartphone. Visit the Apple App Store® or Google Play™ Store on your smartphone to download and install it.
Controlling Your Camera Remotely
The procedure may differ depending on the model, but in general, you can follow these steps:
- After installing the app, visit the Imaging Edge Mobile website.
- Search for your camera model via the category selector at the top, or scroll down the page to see all models.
- Select your camera model, and then refer to the Operating the camera from a smartphone/tablet (remote shooting) section:
- Select [Connecting] for instructions on how to connect your camera and smartphone (e.g., Connecting by QR code, Connecting by Wi-Fi using NFC).
- Select [Operating the camera remotely] for instructions on how to access different camera settings from your smartphone (e.g., Zoom, Camera Remote Power ON/OFF, Mirror Mode).
- Follow the steps provided.
Questions & Answers
Which Sony cameras are compatible with Imaging Edge Mobile?
