Article ID : 00281492 / Last Modified : 22/08/2025Print
    The Auto Power Off setting on the INZONE headphones doesn't work
    The Auto Power Off feature activates when the INZONE headphones aren't connected to a gaming device (computer or PlayStation5) or any Bluetooth device (e.g. smartphone) for 5 minutes, and the headphones aren't operated. However, the Auto Power Off feature will not activate under the following conditions:
    • When the headphones are connected to the PlayStation 5 console via the USB transceiver and the console goes into Rest Mode. To turn off the headphones, manually turn them off or disconnect the USB transceiver.
    • When the headphones are charging.
    Note: You can disable or change the time after which the Auto Power Off feature activates using the INZONE Hub software.
