Article ID : 00398602 / Last Modified : 20/04/2026Print
How to check the remaining battery charge of the gaming headphones
    You can see the remaining battery charge using the headphones' indicator(s):
    • When you turn on the headphones, and there is enough remaining battery charge (20% or more), the indicators light up:
      • INZONE Buds: The indicator on the charging case lights up in orange
      • INZONE H9 II:
        • The power indicator flashes in white twice when you turn on the headphones
        • A voice guidance indicating the remaining battery charge can be heard when you press the power button
      • INZONE H9: The ring indicators light up in white or blue for about 5 seconds
      • INZONE H5/INZONE H7: The power indicator lights up in white for about 2 seconds
    • For INZONE H5, INZONE H7 and INZONE H9: when the remaining battery charge is 20% or lower, the headphones' indicator flashes orange for about 15 seconds.
    • To see more details about the remaining battery charge:
      • When the headphones are connected to a computer, use the INZONE Hub software to see a battery icon that displays the remaining battery charge in one of 4 levels: 100%, 70%, 50%, or 20%.
      • For INZONE H7 and INZONE H9 only: When the headphones are connected to a PlayStation®5, use the Accessories screen in the Control Centre to check the remaining battery charge.
      • For INZONE H9 II only: When the headphones are connected to a smartphone, you can check the remaining battery charge using the Sony | Sound Connect app.
