Article ID : 00186325 / Last Modified : 16/01/2026Print
    Headset does not power off. WF-1000X
    If there is no charge remaining in the charging case’s rechargeable battery, the headset will not power off automatically.
    When powering off the headset, remove it from the charging case, then press and hold the left unit button until the blue indicator flashes (approx. 2 sec.). The left and right units will power off at the same time.
