Article ID : 00285257 / Last Modified : 20/01/2026Print
There is no sound, or sound is only heard from one side of the headphones. (WF-1000XM4)
    Before you start
    • If foreign substances (such as earwax) build up in the earbuds, no sound may come out or the volume may seem lower than usual. Regular cleaning can prevent these issues. For details, refer to the How to care for the headphones article.
    • Turn up the volume on the connected device.
    Solution
    1. Select your issue:
      I cannot hear sound when playing music.
      Go to step 2.
      I cannot hear voice while on a phone call.
      See the While on a phone call I cannot hear the other party's voice or they cannot hear mine article.
    2. Pause the music, wait for about 10 seconds, and play the music again.
      I can hear sound from the headphones.
      The Bluetooth connection may have been temporarily unstable.
      I cannot hear sound from the headphones.
      Go to step 3.
    3. Turn off and on the headphones:
      Set the headphones in the charging case, close the lid, wait for about 10 seconds, and then wear the headphones again.
      The issue may be caused by a temporary malfunction of the headphones.
      Go to step 4.
    4. Select your issue details:
      I can hear sound from only one side of the headphones.
      Go to step 5.
      I cannot hear sound from either side of the headphones.
      Go to step 7.
    5. Check if the Google Assistant or Amazon Alexa is set to the headphones.
      The Google Assistant or Amazon Alexa is set to the touch sensor.
      Go to step 6.
      These functions are not set to the touch sensor, or I don't know whether these functions are set.
      Go to step 7.
    6. Check the touch sensor control function or Voice Assistant function according to the way you use the headphones:
      When the Google Assistant or Amazon Alexa is set to the headphones, only the side with the touch sensor control function set to Playback control can be used alone.
      • If you want to use either side of the headphones: Set the touch sensor control function of the desired side to Playback control. Follow these steps to set the touch sensor control function to Playback control:
        1. Open the Sony | Headphones Connect app.
        2. In the System tab, select settings at the right side of the Change the touch sensor function menu.
        3. Select the side you want to use alone, either L (Left) or R (Right), and set the Function to Playback control.
        Note: When you assign Playback control to both sides, full functionality is only available on the Right side.
      • If you want to use both units alone respectively: Set the Voice Assistant function to Voice Assist Function of Mobile Device. With this setting, either side of the headphones can be used alone.
        2. Select down arrow at the right side of the Voice Assistant menu.
        3. Select Voice Assist Function of Mobile Device.
      After changing the settings, I can hear sound from the headphones.
      The headphones settings were the cause of the issue.
      Go to step 7.
    7. Try the following procedure, and check if you can hear sound from the headphones:
      1. Charge the headphones.
        Note: Use the USB Type-C cable that is supplied with the product. Charging may not be possible with a commercially-available cable.
      2. Initialize the headphones.
        Note: Initialization returns the headphones to the factory settings and all Bluetooth pairing information is deleted.
        Refer to the Initializing the headphones to restore factory settings article to initialize the headphones.
      3. Restart the playback device.
        Since the playback device may be temporarily malfunctioning, turn off the device once, and turn it on again.
      4. Delete the Bluetooth device information of your playback device.
        For details on how to delete the Bluetooth device information, refer to the How to delete the Bluetooth device information of your playback device article.
      5. Perform pairing again.
        Refer to the appropriate article:
      There seems to have been an issue connecting with the playback device, such as Bluetooth pairing being disconnected.
    8. If you connect a computer with the headphones, check the settings on the computer, check the computer settings:
      1. On the right side of the computer screen, right-click the Speaker icon.
      2. Open the Sound settings, and then select Sound Control Panel.
      3. Select Playback tab to show device list.
      4. Select the connected headphones, and click Set Default.
      5. Select OK to close the setting screen.
      The issue is resolved
      The issue may have been caused by the computer settings.
      The issue is not resolved
    Go to the Headphones Troubleshooting Guide
