Article ID : 00353186 / Last Modified : 26/03/2026Print
    Learn about the head tracking function on Sony headphones or earbuds
    What is the head tracking function on Sony headphones?
    The head tracking feature improves your listening experience by adjusting spatial sound based on how you’re wearing your headphones. It helps create a more immersive and realistic sound, especially when paired with supported Android devices and apps that offer spatial audio.
    Head tracking uses the Sony | Headphones Connect app to detect how your headphones sit on your head. It then adjusts the spatial sound to match, so the audio feels more anchored and lifelike—even as you move.
    Which Sony headphones or earbuds support head tracking?
    This feature is available on the following Sony headphone models:
    • WH-1000XM6
    • LinkBuds Open (WF-L910)
    • LinkBuds Fit (WF-LS910N)
    • ULT WEAR (WH-ULT900N)
    • WF-1000XM5
    • WH-1000XM5* (Need latest firmware update)
    • LinkBuds (WF-L900)* (Need latest firmware update)
    • LinkBuds S (WF-LS900N)* (Need latest firmware update)
    How to update your Headphones or Earbuds:
    1. Download the Sony | Headphones Connect app.
    2. Connect your headphones to the app.
    3. Follow the instructions to start the update.
    Tip: Updating regularly ensures you get the best performance and newest features!
    Note: Head tracking may not be available on all Android devices. Support depends on your phone model and Android version.
    How to turn on head tracking
    1. Open the Sony | Headphones Connect app.
    2. Go to My Devices.
    3. Tap Device settings.
    4. Select Spatial sound and head tracking.
    5. Tap Measure to begin setup.
    Head tracking activation steps in app
