Article ID : 00354960 / Last Modified : 22/05/2025Print
Tips for avoiding high-pitched howling feedback on LinkBuds Fit (WF-LS910N)
    If you hear a high-pitched howling sound when using your LinkBuds Fit, it’s not because you’re wearing them during the full moon and are being chased by a werewolf.
    Instead, due to the enhanced noise-canceling and external sound-capturing capabilities, touching the microphone or covering or pinching the earbuds may generate noise feedback.
    3 tips to avoid high-pitched feedback on the Linkbuds Fit
    1. When touching your LinkBuds Fit, touch them lightly and try to avoid the microphones (marked as A on the picture below).
      microphone placement on Linkbuds Fit
    2. Don’t cover your earbuds with your hands or other objects.
    3. Lower the ambient sound volume in [Ambient Sound Control] on the Sony | Sound Connect app to reduce the outside sound level.
