Below is a table of frequently asked questions (FAQs) about the video specifications of HDMI connection when using the UHP-H1.
Q1: What is the highest resolution that can be output from HDMI (HDMI1, HDMI2)?
A1: 4K 24P/60P from HDMI1 only.
Q2: How to output the optimum resolution.
A2: To output the optimum resolution, set Output Video Resolution to Auto on the Blu-ray Disc Player.
Follow the steps below:
- Press the HOME button on the remote.
- Select Setup.
- Select Output Video Resolution in the Screen Settings category.
- Select Auto.
Q3: Can HDMI (HDMI1, HDMI2) output to 2 unidentical TVs?
A3: Yes. It can be connected using HDMI cables either through an amp or directly to a TV. (The exception is 4K TVs, which only can be connected via HDMI1.)
Q4: Can both HDMI (HDMI1, HDMI2) output the same resolution?
A4: This depends on the specifications of your TV. Once you set the resolution output, the Blu-ray Disc Player will determine the highest common resolution that each TV can support.
Q5: When connecting to the TV via an amplifier, there is no picture on the TV screen.
A5: If the connected amp or TV is not compatible with 4K, there is no picture on the TV screen when Output Video Resolution in Screen Settings of the Blu-ray Disc Player is set to 4K.
In this case, try the following:
- If the TV is not compatible with 4K:
Set Output Video Resolution in Screen Settings to Auto. - If the amp is not compatible with 4K:
Set Output Video Resolution in Screen Settings to Auto, or connect the Blu-ray Disc Player directly to the TV with an HDMI cable.
Q6: Will there be a difference in audio output format depending on whether the Blu-ray Disc Player is connected to the TV through an amplifier or without amplifier?
A6: This depends on your TV and without amplifier settings. The highest available format will be selected.
Q7: Does Hi-Res sound apply for HDMI audio?
A7: Yes, it supports Hi-Res sound.
Q8: What are the supported audio formats for HDMI Hi-Res audio?
A8: The following formats are compatible:
- DSD (DSF and DFF)
- FLAC
- ALAC
- AIFF
- WAV
Q9: Why did resume playback take around 4-6s before the picture appeared?
A9: Because the transition process of output resolution takes time until the picture is normally output to the connected device.
Q10: Can I change output from the amplifier speakers to the TV speakers during playback?
A10: In the amplifier setting, choose TV output for audio, rather than the amplifier.
Q11: Can this Blu-ray Disc Player play a 4K UHD disc?
A11: This Blu-ray Disc player currently does not support 4K UHD or 4K native video format.
