Each time the Blu-ray Disc player is turned on, the player performs a system check. Because of this system check, it may take approximately 30 seconds for the Blu-ray Disc player to start when you set the Quick Start Mode setting to ON.
However, this should only occur the first time the player is turned on after changing the setting.
From the second time onward, after the Blu-ray player goes through this initial boot-up sequence, the normal boot-up time will be within one second.
