Article ID : 00059672 / Last Modified : 30/03/2021Print
    Will the LA-EA4 lens mount adapter work with my camera?
    Yes, the LA-EA4 will work with your camera.
    NOTES:
    • If your model is NEX-3, NEX-C3, NEX-5 or NEX-VG10E, a firmware update is required for it to work with the LA-EA4 adapter.
    • When the LA-EA4 is attached, the Autofocus Area can only be set to Wide mode.
