Resetting the headphones
If the headset cannot be turned on or cannot be operated even when it is turned on, reset the headset.
Note: Resetting will not delete any data or pairing information.
Connect the headset to an AC outlet.
Use the supplied USB Type-C cable and a commercially available USB AC adaptor.
The charging indicator (orange) lights up.
A: USB AC adaptor
Press and hold the
(power) button and the CHAT button for about 5 seconds.
After the charging indicator (orange) turns off, release the
(power) button and the CHAT button.The headset will be reset.
Initializing / Reformatting the headphones to restore factory settings
Notes:
- The configurations of various settings are reset to the factory preset values.
- Bluetooth pairing information is deleted.
Turn off the headset.
Remove the USB Type-C cable.
Press and hold the
(power) button and the CHAT button for about 10 seconds.
When initializing is complete, the
(power) indicator (white) flashes 4 times.
