Applicable Model
This information is for the following model(s):
- K-43S3 / BRAVIA 3 (S30)
- K-50S3 / BRAVIA 3 (S30)
- K-55S3 / BRAVIA 3
- K-65S3 / BRAVIA 3
- K-75S3 / BRAVIA 3
- K-85S3 / BRAVIA 3
The update is compatible with all firmware versions of all applicable model(s).
About this download
Benefits and Improvements
- Improves performance and stability of overall UI operation
- Improves general TV performance
Previous Benefits and Improvements
View previous benefits and improvementsRestrictions
- Only for use with TV sold in Europe. Not all models are sold in all countries/regions.
- Make sure your model is in the list of Applicable models mentioned at the top of this page.
- Do not attempt to install this software on a TV model which is not listed on this page. Doing so could potentially create issues with functionalities of your TV.
Preparation
Check the software version
Your software may already be up to date. If you're not sure, it's easy to check which version of software you have by following these instructions:
- Using the remote control, turn on your TV, and then press the HOME button.
- Select Help.
- On the TV screen, the software version number is shown below the model name.
- Model: K- / Y-xxxxxxxx
- Software version: xxxxxxxx
If the version number is 6120900201 or higher, you already have the most recent software version and updating is not required.
There are 2 ways to update the firmware on your BRAVIA TV:
- Using the System software update feature (easy)
- Using a USB flash drive
Using the System software update feature (easy):
Sony provides software updates in order to enhance functionalities and provide users with the latest TV experience. The easiest way to receive software updates is via the internet connection to the TV.
If you get the notification for a system software update, you can install it from the Home Menu.
The new firmware update will be rolling out gradually to all Internet-connected TVs over the weeks following its release.
IMPORTANT: The following "System Requirements," "File Info," and the "Download & Install" sections relate to the USB flash drive update procedure. You can ignore them if you completed the update using the "System software update" feature.
For other FAQs about Troubleshooting, please see the Questions and Answers on the Sony Support Site.
Using a USB flash drive:
You can also update the software by using a USB flash drive. If an Internet connection is not set up on your TV, or you don’t want to wait for the update via System software update feature, try to download and update using a USB flash drive as instructed below.
System Requirements
What You Need
- a computer with access to the Internet
- a USB flash drive
* You can update your TV even if there are other files in the USB flash drive.
File Info
File Name
- Firmware update to v6120900201 for TV
Zip File Name
- sony_atvotafull_braviabf1_6120900201_www_auth.zip
File Version
- 6120900201
File Size
- 1 551 492 152 bytes
Release Date
- 07-10-2026
Download & Install
Important Notice
- This update is necessary to maintain the conformity of the product.
- Read the instructions carefully or you could end up causing the TV to become unresponsive or require a repair.
- Do not turn the TV off - or disconnect it from the power - while it's updating.
- Do not press any buttons, except the ones mentioned in the instructions.
How to download the Updater
Before you install the update, you'll need to download it from the Internet and save it to a USB flash drive.
- Download the update file to your PC.
- Click the Download button on the top of this page, then read and accept the terms and conditions.
- Click the Download button on the bottom of the page to download the update file on your PC.
- Verify the downloaded file name and size (see the File Info section).
- Insert the USB flash drive into your PC.
- Copy or drag and drop the file (sony_atvotafull_xxxx_xxxx_xxxx_xxxx.zip) to the root directory of your USB device.
Note: The root directory is the first or top-most directory of the device, which contains all the other folders. - Remove the USB flash drive from your computer and continue to the next section.
Step 1: Install the update
Once you've downloaded the update file and prepared your USB device, you can install it on your TV. The process can take up to 15 minutes and during the installation your TV will turn off before turning itself back on. Please follow the simple steps below:
- Turn on the TV.
- Make sure that no USB devices are inserted into your TV.
- Insert your USB flash drive containing the file (sony_atvotafull_xxxx_xxxx_xxxx_xxxx.zip) into a USB port of the TV set.
Note: Any USB slot can be used if the TV has multiple USB ports. - Once the USB flash drive has been detected, a series of different messages will appear on the TV set. Follow the on-screen instructions.
Note: If the messages do not appear automatically, try turning the TV off and on with the remote control. - When the file is finished copying from the USB flash drive, the update process will begin, the POWER indicator on the TV will begin flashing white.
- After several minutes, the TV will turn off and then turn back on to complete the update.
WARNING! During the software installation process:- Do not remove the USB device
- Do not turn off the TV
- Do not disconnect the TV from the power supply
- When the software update is complete, a message appears on the TV indicating the software update is complete.
- Carefully remove the USB device from the USB slot.
Step 2: Check that the update was successful
Check the current software version to confirm that the update has successfully been installed.
- If the version number is 6120900201, the software update was successful.
- If the version number isn't 6120900201, download and install the update again.
Questions & Answers
Possible Issue During the Update
Need more information? See our FAQs about updating the software over the Internet:
Will my personal settings be deleted after the update?
No, all your personal settings will be kept. -
Can I install an older version of the software?
No, To ensure that your TV remains at optimum performance, the installation of an older software version is not possible: the latest software version contains all the benefits and improvements of previous versions. -
Is it normal for the TV to turn off during the update process?
Yes, it’s normal for the TV to restart during the update process. It will take a longer time for the TV to restart while installing the new software.
What to do if you have problems updating your TV firmware
If the message An error occurred during the software update is displayed on the TV screen, please proceed to the following procedures for a possible solution:
- Make sure the TV has at least 4 GB available in the storage.
- Press the HOME button on the Remote Commander to display the Home Menu.
- Navigate to Settings and select it.
- Navigate to Device Preferences and select it.
- Navigate to Storage and select it.
- Navigate to Internal Shared Storage and select it.
- Navigate to Available and check the current available storage.
- Turn off the TV by pressing the POWER button on the TV set.
- Press the POWER button again, and proceed with the installation process again.
- If the message No newer version of the TV software was found is displayed on the TV screen, your TV already has the newest software version installed, so you don't need to update it.
- If the update still fails, format the USB flash drive to FAT32 and try again.
Note: If you are trying to update the software using a USB flash drive, make sure your USB flash drive is in good working order.
For other FAQs about Troubleshooting, please see the Questions and Answers section on the Sony Support Site.
