Applicable Model
This information is for the following model(s):
- K-55XR80 / BRAVIA 8
- K-55XR83 / BRAVIA 8
- K-55XR84 / BRAVIA 8
- K-55XR8A / BRAVIA 8
- K-65XR80 / BRAVIA 8
- K-65XR83 / BRAVIA 8
- K-65XR84 / BRAVIA 8
- K-65XR8A / BRAVIA 8
- K-77XR80 / BRAVIA 8
- K-77XR83 / BRAVIA 8
- K-77XR84 / BRAVIA 8
- K-77XR8A / BRAVIA 8
This update is compatible with all firmware versions of all applicable model(s).
Before you start
Read this section before downloading the file.
- Only TVs running software version 114.602.030.1 or later can be updated in a single step. If the version number of your TV is lower than 114.602.030.1, check the current software version before proceeding.
- If the version number of your TV is lower than 114.602.030.1 but is 112.634.100.2 or later, install the software version 114.602.030.1 before updating to 114.603.100.1.
- If the version number of your TV is lower than 114.602.030.1 but is 112.602.120.1 or later, install software versions 112.634.100.2 and 114.602.030.1 before updating to 114.603.100.1.
About this download
Benefits and improvements
- Resolves an issue where audio could gradually become delayed under certain conditions
- Resolves an issue where the file support of the internal media player was degraded
- Enhances security
- Improves general TV performance
Previous benefits and improvements
View previous benefits and improvementsWhat to keep in mind
- Only for use with TVs sold in Europe. Not all models are sold in all countries/regions.
- Before downloading the update, make sure your model is in the list of Applicable Products mentioned at the top of this page.
- Do not attempt to install this software on a TV model that is not listed on this page. Doing so could create issues with your TV's functionality.
Preparation
Check the software version
Your software may already be up to date. If you're not sure, it's easy to check which software version you have by following these instructions:
- On the TV remote control, press the
(Input) button, then select Help.
Note: If Help is not shown in the input selection screen, select Edit and add Help. - On the TV screen, the software version number is shown below the model name.
- Model: K- / XR- / XRM- / Y-xxxxxxxx
- Software version: XXX.XXX.XXX.X
If the version number is 114.603.100.1 or higher, you already have the most recent software version and do not need to update.
How to update the firmware on your BRAVIA TV
Choose one of the following procedures:
- Using the Automatically check for update function (easy)
Note: Your TV may indicate the Software is up to date even if the newer version is not installed. The updates for automatic software downloads are staggered releases and may not be immediately available. Please try again later. If you prefer to update now, follow the instructions to download and install the software update using the USB flash drive method. - Using a USB flash drive
Using the Automatically check for update function (easy):
Sony provides software updates to enhance functionalities and provide users with the latest TV experience. The easiest way to receive software updates is to use the Automatically check for update function. This setting is enabled by default.
If you have enabled Automatically check for update below, you will automatically receive a notification to update your TV.
Note: If Help is not shown in the input selection screen, select Edit and add Help. - Select Status & Diagnostics.
Note: If Status & Diagnostics is not shown, skip this step. - Select System software update.
- Select Automatically check for update.
The new firmware update will roll out gradually to all Internet-connected TVs following its release.
IMPORTANT: The System Requirements, File Info, and Download and Install sections below relate to the USB flash drive update procedure. You can ignore them if you completed the update using the Automatically check for update function.
For other FAQs about troubleshooting, please see the Questions and Answers section on the Sony Support Site.
Using a USB flash drive:
You can also update the software by using a USB flash drive. If an Internet connection is not set up on your TV, or you don’t want to wait for the update via the Automatically check for update function, try to download and update using a USB flash drive as instructed below.
System requirements
What you need
- a computer with access to the Internet
- a USB flash drive
Note: You can update your TV even if there are other files in the USB flash drive.
File info
File name
- Firmware update to v114.603.100.1 for TV
Zip file name
- sony_tvota_2022_1146031001_eua_auth.zip
File version
- 114.603.100.1
File size
- 3 117 639 233 bytes
Release date
- 24-09-2026
Download and install
Important notice
- This update is necessary to maintain the conformity of the product.
- Read the instructions carefully or you could end up causing the TV to become unresponsive or require a repair.
- Do not turn off the TV or disconnect it from power while it's updating.
- Do not press any buttons, except the ones mentioned in the instructions.
- Stop any recording before you start the firmware update (USB HDD recording models only).
How to download the updater
Before you install the update, you'll need to download it from the Internet and save it to a USB flash drive.
- Click the Download button at the top of this page, then read and accept the terms and conditions.
- Once you have accepted the terms and conditions, click the Download button at the bottom of the page to download the update file to your computer.
- Verify the downloaded file name and size (see the File Info section).
- Extract the downloaded file to a location on your computer that you can easily find.
- Ensure the newly created sony_tvota_2022_YYYYYYYYYY_yyy_auth folder contains the following files:
- sony_tvpart_2022_YYYYYYYYYY_wwa_auth.zip
- sony_tvpart_2022_YYYYYYYYYY_wwa_auth_xxxx.dep
- sony_tvsup_2022_YYYYYYYYYY_yyy_auth.zip
- Insert the USB flash drive into your computer.
- Go to the location where the extracted files are saved and copy (or drag and drop) the three files from the sony_tvota_2022_YYYYYYYYYY_yyy_auth folder into the root directory of the USB flash drive.
Note: The root directory is the first or top-most directory of the device, which contains all the other folders. - Remove the USB flash drive from your computer and continue to the next section.
Step 1: Install the update
Once you've downloaded the update file and prepared your USB device, you can install it on your TV. The process can take up to 30 minutes, and during the installation, your TV will turn off before turning itself back on.
Follow these steps to install the update:
- On the TV remote control, press and hold the POWER button for at least 3 seconds and select Restart. Depending on the model and OS, you may need to press and hold the POWER button of the remote control for about 5 seconds, or until the message Power off appears.
- Make sure that no other USB devices are inserted into your TV.
- Connect the USB flash drive containing the three extracted files to a USB port on the TV set.
Note: If the TV has multiple USB ports, any of the USB slots can be used. - Once the USB flash drive has been detected, a series of different messages will appear on the TV set. Follow the on-screen instructions.
Note: If the messages do not appear automatically, use the remote control to turn the TV off and back on again. - The update process will begin, the POWER indicator on the TV will begin flashing white, and the update progress screen will be displayed on the TV.
- After several minutes, the TV will turn off and then turn back on to complete the update.
WARNING! During the software installation process, please:- Do not remove the USB device
- Do not disconnect the TV from the power supply
- The TV will restart automatically once the update is completed.
- Carefully remove the USB device from the USB slot.
Step 2: Check that the update was successful
Check the current software version to confirm that the update was successfully installed.
- If the version number is 114.603.100.1, the software update was successful.
- If the version number isn't 114.603.100.1, download and install the update again.
Questions and answers
FAQs
- Will my personal settings be deleted after the update?
No, all your personal settings will be kept. - Can I install an older version of the software?
No. To ensure that your TV remains at optimum performance, the installation of an older software version is not possible. The latest software version contains all the benefits and improvements of previous versions. - Is it normal for the TV to turn off during the update process?
Yes, it's normal for the TV to restart during the update process. It will take longer for the TV to restart while installing the new software. - When should I insert the USB flash drive?
You can insert the USB flash drive when the TV is ON. Please complete the Initial setup before you try the update.
What to do if you have problems updating your TV firmware
If either message An error occurred during the software update or Software cannot be updated using this USB device is displayed on the TV screen, please proceed to the following procedures for a possible solution:
- Turn off the TV by pressing the POWER button on the TV set.
- Press the POWER button again and proceed with the installation process again.
If the message No newer version of the TV software was found is displayed on the TV screen, your TV already has the newest software version installed, so you don't need to update it.
Note: If you are trying to update the software using a USB flash drive, check the following.
- Make sure your USB flash drive is in good working order.
- The drive must be formatted in FAT16, FAT32, exFAT, or NTFS.
- The update can fail even when using a USB flash drive that meets the above conditions, depending on the size and directory structure of other files on the drive. If the update does fail, delete other files and try again with only the update file saved in the USB flash drive. If the update still fails, format the USB flash drive to FAT32 and try again.
