Article ID : 00139240 / Last Modified : 16/01/2026Print
    The camcorder does not display an image when a device is connected through PROJECTOR IN
    The camcorder will not output the image through the PROJECTOR IN jack if the resolution from the connected device is not supported by the camcorder.
    The following are the resolutions supported by the camcorder.
    NTSC
    • 1280x720 (60Hz/50Hz 16:9)
    • 720x480 (60Hz 16:9/4:3)
    • 640x480 (60Hz 4:3)
    PAL
    • 720x576 (50Hz 16:9/4:3)
