Article ID : 00160325 / Last Modified : 16/01/2026Print
    How to copy videos and photos from the internal memory of my Handycam to a memory card
    • What should I do if the internal memory of my Handycam is full or no memory space is available.
    • Can I transfer movies recorded in the internal memory of my Handycam to a SD card?
    You can copy videos and photos from the internal memory of your Handycam to a memory card simply by operating your Handycam without  using a computer.
    Follow the steps below.
    1. Insert a memory card to your Handycam.
      NOTE: For details on the available memory card to your Handycam, refer to the manual supplied with the product.
    2. Select View Image Image button on the Handycam, or select View Image icon Imageon the LCD display.
    3. Select MENU on the right top in the display.
    4. Select Edit/Copy.
    5. Select Copy.
    6. Select Int. Memory > Memory Card.
      NOTE: When you want to copy videos and photos from a memory card to the internal memory of your Handycam, select Memory Card > Int. Memory.
    7. Select Multiple Images or All In Event.
      • Multiple Images: You can select images individually to be copied.
      • All In Event: You can copy all images in the selected date at one time.
        NOTE: You cannot select multiple dates.
    8. Select the type of image you want to copy.
      • HD MOVIE: Movies recorded by high definition image quality (HD)
      • STD MOVIE: Movies recorded by standard definition image quality (STD)
      • MP4 MOVIE: Movies recorded by MP4 format
      • PHOTO: Still images
    9. Select the images or the date you want to copy.
      • Multiple Images: Select the image you want to copy.
      • All In Event: Select the date you want to copy using Image.
    10. Select OK.
    11. Confirmation message and running time will be displayed. Select OK to start copy.
    12. Copy process starts. After copy completed screen appears, select OK to finish the process.
