Article ID : 00266197 / Last Modified : 21/05/2026Print
    No sound from wired headset connected to Xperia smartphone
    If you can hear no sound coming from a wired headset plugged into your Xperia smartphone, it's possible that the headset's plug isn't compatible with your smartphone.
    Compatible plugs
    Xperia smartphones support headsets with a 3-pole or a 4-pole* (3.5 mm diameter) plug, as shown in the images below.
    3-pole plug
    3-pin
    4-pole plug
    (*) NOTE: If you're using a 4-pole-plug headset, make sure it complies with CTIA standards. You can find this information in your headset's instruction manual.
    Incompatible plugs
    Headsets with a 5-pole plug do not work with Xperia smartphones.
    5-pole plug
