Article ID : 00298357 / Last Modified : 18/10/2024Print
Xperia 1 V software release overview
    Welcome to the Xperia 1 V software release page.
    • Each Xperia smartphone receives security and software updates throughout its lifecycle.
    • Software release timings may vary by operator, market, region, or country.
    Latest Software Release
    Date
    Android version
    Software version
    Software improvement
     April 2024
    Android 14
    67.1.A.2.229
    • Game Enhancer performance improvements.
    • Bluetooth usability improvement.
    • Music playback improvement.
    • Security patch level updated. (April 1st, 2024)
    How to check the software version and how to update your Xperia smartphone
    Tip: To check your device's current software version, find and tap Settings → About phone → Build number.
    When a software update is available,  Refresh icon appears in the status bar.
    To download and install a system update from the Notification panel
    1. If you use a device with multiple users, ensure you are logged in as the owner.
    2. Drag the status bar downwards to open the Notification panel.
    3. Scroll down, select the wanted system update, tap the item, and then tap UPDATE
    4. When the download is finished, open the Notification panel again if it is closed, then tap RESTART
    Why hasn't my Xperia phone received an update yet?
    • Software updates are released at different times depending on the operator, market, region, or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific models.
    Previous releases
    Date
    Android version
    Software version
    March 2024Android 1467.1.A.2.220
    • Fixed an issue where it was possible to get stuck at Xperia Logo after U-OSV.
    • Fixed an issue where Game Enhancer could crash under certain circumstances.
    • Security patch level updated. (March 1st, 2024)
    February 2024Android 1467.1.A.2.208
    • GMS package updated to Nov 2023
    • Security patch level updated. (February 1st, 2024)
    December 2023Android 1467.1.A.2.182
    • Security patch level updated. (December 1st, 2023)
    October 2023Introducing Xperia with Android 1467.1.A.2.112
    • Android 14 OS upgrade
    • Security patch level updated. (October 1st, 2023)
    September 2023Android 1367.0.A.4.104
    • Bluetooth LE Audio improvement.
    • GMSCore and Google Dialer versions updated.
    • Security patch level updated. (September 1st, 2023)
    August 2023Android 1367.0.A.4.79
    • Bluetooth LE Audio Broadcast support added
    • Security patch level updated. (August 1st, 2023)
    July 2023 Android 1367.0.A.4.51
    • Touch firmware updated to address additional touch response issues
    • Camera stability improvement
    • Security patch level updated. (July 1st, 2023)
    June 2023
    Introducing Xperia with Android 13
    67.0.A.4.22
    • Touch firmware updated to address touch response issues.
    • Fixed a Video bokeh display issue (associated with a high refresh rate) in Photo Pro.
    • Integrated GMS April 2023 packages
    • Security patch level updated. (June 1st, 2023)
