Article ID : 00262067 / Last Modified : 20/01/2026Print
How do I use Wi-Fi tethering in the 5GHz band on my Xperia smartphone?
    How to use Wi-Fi tethering in the 5 GHz band
    Android 12 or higher
    1. Find and tap Setting → Network and Internet → Hotspot and tethering → Portable hotspot / Wi-Fi hotspot.
    2. Tap the slider beside Use 2.4 GHz only to turn it OFF (grey).
    Android 11
    1. Find and tap Setting → Network and Internet → Hotspot and tethering → Portable hotspot.
    2. Tap AP band and select 5 GHz band preferred.
    3. Tap the slider on the top and turn it ON (blue).
    Notes:
    • 5GHz tethering support varies by model and country/region.
    Why is Wi-Fi tethering automatically changing from 5 GHz to 2.4 GHz?
    "5 GHz band preferred" Wi-Fi tethering operates in the 5 GHz band if there is a frequency that can be used in the 5 GHz band. If the frequency in the 5 GHz band can't be used, Wi-Fi tethering operates in the 2.4 GHz band.
