Article ID : 00232835 / Last Modified : 14/04/2026Print
    How to optimise battery consumption on your Xperia smartphone
    Smartphone batteries are at the heart of your device’s performance. If you’ve noticed your Xperia’s battery draining quickly, these tips will help you optimize battery usage and maintain its health.
    Understanding Battery Health and Performance
    Modern smartphones like Xperia use advanced lithium-ion batteries. These compact, high-capacity batteries power slimmer devices and include features like multiple cameras and dual SIM capabilities. However, all rechargeable batteries age over time, reducing their capacity and performance.
    Battery Care: Xperia devices running Android 8 and above include a feature called Battery Care. This intelligently optimizes charging speed based on your usage habits, such as slowing the charge rate overnight to reach 100% by your usual wake-up time. This helps prevent overcharging and extends battery life.
    Battery Care: Do’s and Don’ts
    • Do use the original charger for your Xperia device.
    • Do keep your device in environments between 0°C and 35°C.
    • Do charge your device partially (20–80%) if storing it for a long time.
    • Don’t leave your device charging after it reaches 100% if Battery Care is not enabled.
    • Don’t expose your phone to extreme temperatures or direct sunlight.
    Tips to Improve Xperia Battery Life
    1. Enable Power-Saving Features
    • STAMINA Mode: Reduces performance and limits background activity.
      • Go to Settings → Battery → STAMINA mode.
      • Activate manually or set Auto Start at a specific battery level (e.g., 15%).
    • Ultra STAMINA Mode: Limits usage to essential apps for maximum battery conservation.
      • Go to Settings → Battery → Ultra STAMINA mode.
    • Battery Care: Optimizes charging to prevent overcharging.
      • Go to Settings → Battery → Battery Care and enable the feature.
    2. Adjust Display and Sound Settings
    • Reduce Brightness:
      • Go to Settings → Display → Brightness level and lower the slider.
    • Enable Adaptive Brightness:
      • Go to Settings → Display → Adaptive brightness and toggle it on.
    • Shorten Sleep Time:
      • Go to Settings → Display → Sleep and select a shorter duration.
    • Turn Off Sounds and Vibrations:
      • Go to Settings → Sound → Advanced and disable unnecessary sounds and vibrations (e.g., keypress feedback).
    3. Manage Connectivity Settings
    • Turn Off Unused Features:
      • Wi-Fi: Go to Settings → Network & Internet → Wi-Fi and toggle it off.
      • Bluetooth: Go to Settings → Connected devices → Bluetooth and toggle it off.
    • NFC: Go to Settings → Connected devices → Connection preferences → NFC and toggle it off.
    • Use Airplane Mode: Ideal in areas with weak signals or when not using data.
    • Go to Settings → Network & Internet → Airplane mode and toggle it on.
    4. Avoid High-Drain Activities
    • Limit GPS use for navigation.
    • Reduce streaming videos and music.
    • Avoid extended gaming or tethering (hotspot) sessions.
    • Use headphones instead of the speaker for media playback.
    5. Identify Battery-Draining Apps
    If your battery drains quickly, check for high-drain apps:
    • Android 10 & Above:
      • Go to Settings → Battery → Battery usage.
      • Tap an app for details and tips to reduce its consumption.
    • Android 15 (Latest):
      • Enhanced battery insights now include AI-driven suggestions to optimize app usage.
      • Access detailed power consumption patterns via Settings → Battery → Battery Health & Insights.
      • Use the new App Hibernation feature to limit power usage by rarely used apps (Settings → Apps → Hibernation).
    Additional Tips
    • Turn off automatic app updates in the Play Store:
      • Open Play Store, go to Settings → Auto-update apps, and select Over Wi-Fi only or Don’t auto-update apps.
    • Close background apps when not in use.
    • Regularly update your device’s software for improved battery efficiency.
    By following these tips, you can enhance your Xperia’s battery performance and enjoy longer usage between charges.
