Article ID : 00349397 / Last Modified : 11/03/2025Print
    How to add album art to audio files on your Xperia smartphone
    What exactly is album art? Album art is the image that appears for a particular song or album in your music library. Official music purchases and downloads usually come with pre-existing album art. However, you can also upload your own image and customise the album art for your audio files (except for certain copyright-protected items).
    Note: The steps for changing the album art vary depending on your Xperia device and media player version.
    There are two ways to add album art to your audio files:
    • Via the pre-installed Music app on your Xperia smartphone
    • Via a third-party app (e.g. iTunes, Mp3tagWindows Media Player, VLC)
    How to add album art using the pre-installed Music app
    1. Find and tap Files.
    2. Under Categories, tap the folder where your audio file is saved (e.g. Audio, Downloads).
    3. Tap the three vertical dots (menu button) next to the file name, then select Open with Music app.
    4. Exit and re-launch the Music app.
    5. Tap the three horizontal lines (menu button) at the top-left of the Music app Home screen, and search for your desired audio file (in Songs, Folders, etc.).
      Note: If the file is saved in a folder other than Songs, tap the file to open it in a new screen.
    6. Tap the three vertical dots (menu button) next to the file name, then select Edit music info.
    7. Tap the pencil icon on the bottom right of the album art box, then select Set image.
    8. Browse your Photos / Albums library for the image you want to use as the album art.
    9. After adjusting the image, tap Save copy.
    10. Tap Save on the top right corner of the screen. The image will now appear as the album art.
      Note: You must fill in the Title and either the Album or Artist fields to save your changes.
    How to add album art using a third-party app
      Click or tap the expandable sections below to get started.
      After updating the album art in the third-party app, you can then transfer the audio file from your computer to your smartphone.
