You can transfer data from the internal storage to a memory card or using a Files application. Depending on your Xperia device, the Files application may be pre-installed on your device. But, you can always download a third-party* file manager app from Google Play.
To Transfer the data (Media file / Documents) using files application.
- Find and tap the Files app
. It's sometimes placed in the Other folder on the Applications screen.
- Tap ”Internal storage" to browse the internal storage, "SD Card" (if available) to browse an external memory card.
- Touch and hold a file to highlight it. You can then share
the file, or tap
and then move or copy the file to another location.
