Article ID : 00232921 / Last Modified : 14/04/2026Print
    I can't connect my Xperia smartphone to my home Wi-Fi network
    Issue: Your Xperia smartphone cannot connect to a Wi-Fi network or has no internet access
    Applies to: Xperia smartphones
    Likely causes: Incorrect network details, temporary connection issues, weak signal, or router configuration
    Resolution: Check if Wi-Fi is turned on and connected correctly, restart your devices, and improve signal strength. If the issue continues, reconnect to the network or complete any required login steps.
    Step 1: check if Wi-Fi is turned on
    1. Go to SettingsNetwork & InternetWi-Fi
    2. Check the Wi-Fi switch:
      • If the switch is ON (blue/active) → Wi-Fi is turned on
        You should see a list of available networks and a Wi-Fi icon in the status bar
      • If the switch is OFF (grey/inactive) → Tap it to turn Wi-Fi on
    3. Turn Wi-Fi off and on again to refresh the connection
    Step 2: check if you are connected to the correct Wi-Fi network
    1. Check your network status:
      • If Connected appears → Your device is connected to Wi-Fi
        If you still have no internet, continue to the next steps
      • If not → Tap your network and enter the password
    Important:
    • Make sure you select the correct Wi-Fi network name
    • If the password has changed, reconnect to the network
    Step 3: restart your devices (quick fix)
    Temporary connection issues are common.
    1. Restart your Xperia smartphone
    2. Turn off your router, wait 1 minute, then turn it back on
    Step 4: improve signal strength
    1. Check the Wi-Fi icon in the status bar:
      • Full or nearly full icon (3–4 bars) → Strong signal
      • Partially filled icon (1–2 bars) → Weak signal
      • No Wi-Fi icon → No signal or not connected
    2. Move closer to your router
    Weak or no signal can prevent your device from connecting or staying connected.
    Signal can be affected by:
    • Walls and floors
    • Metal objects
    • Distance from the router
    Step 5: forget and reconnect to the network
    This resolves many connection issues caused by saved settings.
    2. Tap your network name
    3. Select Forget
    4. Reconnect by selecting the network again and entering the password
    Step 6: complete login for public or guest networks
    Try this if you are using public Wi-Fi (for example in a hotel, café, or office).
    Some networks require a browser login before you can access the internet.
    • Open your web browser after connecting
    • Follow the login page instructions
    Tip: If no page appears, try opening a website manually.
