Article ID : 00237328 / Last Modified : 20/01/2026Print
    Multimedia messaging isn't working
    • Check that MMS (Multimedia Messaging Service) is supported by your network operator and/or subscription.
    • Download settings for internet and MMS automatically.
    • You can manually add internet and messaging settings on your device at any time. If necessary, contact your network operator for the required information.
    • Check the signal strength in the status bar to make sure your device is connected to a network. If the signal is weak or you have no signal, move to an open location free from obstructions, or get close to a window.
    • Check the device memory to see if memory is available. If the memory is full, remove messages to free up space.
    • Check that the MMS auto download function is enabled in your messaging settings.
    • Use the full number when you send a message. When you enter the country code, use "+" instead of "00".
    • Turn off your device and then turn it back on. By doing this you turn off all running applications and free up memory, which sometimes automatically solves the issue.
    • Update your device to ensure that you have optimal performance and the latest enhancements.
