Welcome to the Xperia 10 III software release page.
- Each Xperia smartphone receives security and software updates throughout its lifecycle
- Software release timings may vary per country and operator
Latest software release
| Date | Android Version | Software version | Software improvement |
| September 2023 | Android 13 | 62.2.A.0.533 |
How to check the software version and how to update your Xperia smartphone
Tip: To check your device's current software version, find and tap Settings → About phone → Build number.
When a software update is available, appears in the status bar.
To download and install a system update from the Notification panel
- If you use a device with multiple users, ensure you are logged in as the owner.
- Drag the status bar downwards to open the Notification panel.
- Scroll down, select the wanted system update, tap the item, and then tap UPDATE.
- When the download is finished, open the Notification panel again if it is closed, then tap RESTART.
Why hasn't my Xperia phone received an update yet?
- Software updates are released at different times depending on the operator, market, region or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device. In addition, network operators and specific markets may choose not to use the updates for specific models
Previous releases
| August 2023 | Android 13 | 62.2.A.0.525 |
| May 2023 | Android 13 | 62.2.A.0.481 |
| March 2023 | Android 13 | 62.2.A.0.428 |
| February 2023 | Android 13 | 62.2.A.0.367 |
| 2022 November | Android 12 | 62.1.A.0.675 |
| 2022 September | Android 12 | 62.1.A.0.645 |
| 2022 July | Android 12 | 62.1.A.0.617 |
| 2022 May | Android 12 | 62.1.A.0.587 |
