Note: Products and related services not listed here are not subject to the EU Data Act.
Business & Professional
| HDC-F5500V,HDC-5500V,HDC-3500V,HDC-F5500,HDC-5500,HDC-3500,HDC-3200,HDC-3100,HDC-3170,HDC-P50A,HDC-P50,HDC-P31,HXC-FZ90,HDCU-5000,HDCU-5500,HDCU-3500,HDCU-3100,HDCU-3170,HDCE-TX50,HDCE-TX30,HZCU-FZ90,HDRC-4000,MSU-3000,MSU-3500,RCP-3500,RCP-3100,CNA-2 | XVS-9000,XVS-8000,XVS-7000,XVS-6000,XVS-G1,MLS-X1 | MKS-R4020,MKS-R3210,MKS-R1630,MKS-R1620,MKS-E1620 | DWR-R03D | PDW-U4 | NXLK-IP50Y,NXLK-IP51Y | NXL-ME80 | CBK-RPU7 | BZ40P series, BZ35P series, BZ30P series, BZ53L series, BZ50L series, BZ40L series, BZ35L series, BZ30L series, BZ30J series, EZ20L series | MPC-2610 BURANO,ILX-LR1,PXW-Z200,PXW-Z300 | MPC-3610 VENICE,MPC-3628 VENICE2,MPC-3626 VENICE2,PXW-X400,PXW-Z450,PXW-Z750 | ASR-CT1 | |
| App and service names essential for data collection (not collected if not used) | N/A | N/A | N/A | Wireless Studio | XDCAM Drive Software | N/A | N/A | N/A | N/A | Monitor & Control AND/OR Creators' App | N/A | N/A |
| a-1: Types of product data that can be generated | Configuration settings | Configuration settings, Usage logs | Configuration settings, Usage logs | Configuration settings, Usage logs | Configuration settings, Usage logs | Configuration settings, Usage logs | Configuration settings, Usage logs | Configuration settings, Usage logs | Configuration settings, Usage logs | Usage logs, Setting backup | Setting backup | Configuration settings, Usage logs, Settings backup |
| a-2: Product Data Format | JSON,XML,TEXT,BINARY | JSON,XML,TEXT,BINARY | TEXT,BINARY | Text | Text | TEXT,BINARY | JSON,TEXT,CSV,BINARY | JSON,TEXT,BINARY | TEXT | CSV,BINARY,TEXT | TEXT,BINARY | JSON,BINARY |
| a-3: Estimated volume of product data | typ. 5MB | typ. 10MB | typ. 6MB | max. 40MB | max. 30days worth of files | typ. 13MB | typ. 50MB | typ. 50MB | No Limit | typ. 2MB | typ. 1MB | typ. 300MB |
| b-1: Continuous and real-time generation of product data (available on request) | No | No | No | No | No | No | No | No | No | No | No | No |
| c-1: Whether your connected product has the ability to store data on your device or on a remote server | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes | Yes |
| c-2: Data retention period (if data can be stored) | Until user delete data. | Until user delete data. | Until user delete data. | Until 40MB or user deleting | Until 30days worth of files or user deleting | Until user delete data. | Until user delete data. | Until user delete data. | While the device is in use. | As long as it is necessary for the relationship with users or otherwise permitted or required under applicable law. | As long as it is necessary for the relationship with users or otherwise permitted or required under applicable law. | Until user delete data. |
| d-1: How users can access data, how users can retrieve data, and (if applicable) how users can delete data and the technical means to do so | The methods for extracting and deleting data are described in the user manual. | The methods for extracting and deleting data are described in the user manual. | The methods for extracting and deleting data are described in the user manual. | Users are requested to file an application for data provision at https://services.sony.ie/supportmvc/en/Contact/datarequestpersonaluse (for individual requests) or https://services.sony.ie/supportmvc/en/Contact/datarequest3rdparty (for third-party requests). | Users are requested to file an application for data provision at https://services.sony.ie/supportmvc/en/Contact/datarequestpersonaluse (for individual requests) or https://services.sony.ie/supportmvc/en/Contact/datarequest3rdparty (for third-party requests). | The methods for extracting and deleting data are described in the user manual. | The methods for extracting and deleting data are described in the user manual. | The methods for extracting and deleting data are described in the user manual. | Refer to Android Debug Bridge (adb) (https://developer.android.com/tools/adb) |
Users are requested to file an application for data provision at https://services.sony.ie/supportmvc/en/Contact/datarequestpersonaluse (for individual requests) or https://services.sony.ie/supportmvc/en/Contact/datarequest3rdparty (for third-party requests). The methods for extracting and deleting data are described in the user manual. |
| d-2: Terms of Use and Quality of Service | Terms of use and quality of service are provided at https://www.sony.ie/electronics/support/articles/00365283. | Terms of use and quality of service are provided at https://www.sony.ie/electronics/support/articles/00365283. | Terms of use and quality of service are provided at https://www.sony.ie/electronics/support/articles/00365283. | Terms of use and quality of service are provided at https://www.sony.ie/electronics/support/articles/00365283. | Terms of use and quality of service are provided at https://www.sony.ie/electronics/support/articles/00365283. | Terms of use and quality of service are provided at https://www.sony.ie/electronics/support/articles/00365283. | Terms of use and quality of service are provided at https://www.sony.ie/electronics/support/articles/00365283. | Terms of use and quality of service are provided at https://www.sony.ie/electronics/support/articles/00365283. | Terms of use and quality of service are provided at https://www.sony.ie/electronics/support/articles/00365283. | Terms of use and quality of service are provided at https://www.sony.ie/electronics/support/articles/00365283. | Terms of use and quality of service are provided at https://www.sony.ie/electronics/support/articles/00365283. | Terms of use and quality of service are provided at https://www.sony.ie/electronics/support/articles/00365283. |
