Applicable Model
This information is for the following model(s):
  • KBD-G900 / INZONE KBD-H75
  • KBD-G900DE / INZONE KBD-H75
  • KBD-G900FR / INZONE KBD-H75
  • KBD-G900NO / INZONE KBD-H75
  • KBD-G900UK / INZONE KBD-H75
  • MSE-G500 / INZONE Mouse-A
  • IER-G900 / INZONE E9
  • INZONE H3 / MDR-G300
  • INZONE H7 / WH-G700
  • INZONE H9 / WH-G900N
  • WF-G700N / INZONE Buds
  • WH-G500 / INZONE H5
About This Download
The INZONE Hub is a computer software application that allows you to customize various sound settings and save those settings for each game.
Benefits and Improvements
  • Adds support for INZONE KBD-H75 (KBD-G900) keyboard layouts for the following languages:
    • English (UK)
    • German
    • French
    • Norwegian
  • Improves general functionality
Previous Benefits and Improvements
System Requirements
Operating Systems
  • Windows 11 Home/Pro
CPU
  • Intel Core i5 CPU or later (8th generation or higher)
  • AMD Ryzen 5 or higher
HDD/SSD
  • Free space: 400 MB or more
Notes
  • The following systems are not supported:
    • Personally constructed computers or operating systems
    • Upgraded operating systems
    • Multi-boot environments
  • The computer should at least meet the above system requirements. However, Sony does not guarantee operation on all computers even if they meet these system requirements.
  • It is also necessary to meet the requirements for each OS and game application.
  • Please use the latest drivers available.
  • If you use a laptop computer, connect it to an AC adapter, as the update may not operate normally due to the power-saving function.
File Info
  • Name: INZONEHub_Setup_1.0.18.2.exe
  • Version: 1.0.18.2
  • Size: 138 MB (144 723 496 bytes)
  • Release Date: 25-02-2026
Preparation
  • During the installation of this file, make sure you are logged in as the Administrator or as a user with administrative rights.
  • To ensure that no other program interferes with the installation, save all your work and close all other programs.
Notes:
  • This application is available to users of supported devices manufactured by Sony.
  • Depending on your internet connection method, your internet provider contract, etc., fees may be charged when you download the application.
  • Sony bears no responsibility for direct or indirect losses that occur due to the use of this application.
  • The supplied application is protected by copyright. You may not copy or redistribute the application, or use it for purposes other than those defined by Sony.
  • If you install the application somewhere other than the default location, check that you have permission to access and make changes to that folder. Update the folder permissions if necessary.
Download and Install
Before you start the download, make sure to log in to your computer as an Administrator.
  1. Download the file to your computer.
  2. Quit all software running on your computer.
  3. Double-click the saved file and follow the on-screen instructions.
  4. When the message indicating the upgrade is complete is displayed on the computer screen, click Close.
After installation, start the INZONE Hub software from the start menu or shortcut on your computer, and then connect your INZONE device.
Note: If you go to Settings and select LAUNCH INZONE HUB AT PC STARTUP, the INZONE Hub software will start automatically from now on.
