Thank you for your continued patronage of Sony products.
Sony will terminate the following assistant functions used on Xperia Touch (G1109) on March 31, 2023:
- Voice control (check date and time, search route, set timer, etc.)
However, you can continue to use the Google Assistant function. As a projector, you can also continue to use the smart screen function and others as before.
Additionally, the application System software for Xperia Touch and Xperia Hello!, available on the Google Play store, will be discontinued in November 2022 and thereafter.
We want to express our deepest gratitude for your patronage and apologize for any inconvenience caused to our customers. We appreciate your understanding.
* Please note that due to the termination of the above functions, you will not be able to use this function even if there is a description of this function in promotional materials such as catalogues, product packaging boxes, instruction manuals, etc.
