Article ID : 00342236 / Last Modified : 10/06/2025Print
Is the REON POCKET / TAG waterproof?
Can I use the REON POCKET during exercise?
    The REON POCKET / TAG is designed to be splash-proof, but it does not completely prevent the incursion of dust and water droplets.
    It has waterproof sealing on the parts that come in contact with the skin.
    The REON POCKET is intended for use in daily outings, commuting, and light exercise (e.g. walking, golfing). Please note that this product is not waterproof.
    Please refrain from using the product in the following environments.
    • Strenuous work or exercise (e.g. running) at a level that causes intense sweating
    • Rain, snow, or other conditions where the device is exposed to moisture
    • Prolonged use under a hot sun
