Article ID : 00167808 / Last Modified : 29/03/2019Print
    How to access the Device Manager
    There are two easy ways to access the Device Manager:
    • Point to (but do not click) the lower-right or top-right corner of the screen, click to select the Search charm, and in the Search field, type Device Manager and then press the Enter key.
    • Press the Windows Logo + X key combination on the keyboard and, from the list, click Device Manager.Image
    NOTE: Because the Device Manager is a traditional Windows Desktop application, whichever method you use, the interface will change to the Desktop and the Device Manager window will open.
