Applicable Model
This information is for the following model(s):
  • SLS-1A
About This Download
Benefits and improvements
  • Vulnerability management
    (Applying patches to the kernal.)
File Info
  • File Name: LA1_H105+D100+Z105.upg
  • File Version: 1.010
  • File Size: 16,299,148 bytes
  • Release Date: 20-05-2024
System Requirements
What you need
  • A computer with the Line-Array Speaker Manager app installed
Download & Install
Important notice
  • During the update, do not unplug the power cord of the SLS-1A speaker.
How to download the update file
  1. Click the Download button on the top of this page, then read and accept the terms and conditions.
  2. Once you accept the terms and conditions, click the Download button on the bottom of the page to download the update file to your computer.
  3. Verify the downloaded file name and size (see the File Info section).
  4. Save the file to a location on your computer you can easily find.
How to install the update
  1. Start the Line-Array Speaker Manager app on your computer.
  2. Select the Device tab.
  3. Select the  (updating icon), then click Select File on the Update Setting window.
  4. Select the update file which you downloaded.
  5. Click Update to apply the update file.
    • When the update is complete, the SLS-1A speaker will automatically restart.
      Note: You can update SLS-1A speakers on a group basis as well.
