Please check the following.
- Wireless devices, such as a router, cordless phone, wireless TV receiver, radio, wireless camera, Bluetooth device, or microwave, emit strong radio waves that may disrupt Wi-Fi Direct performance.
We recommend these wireless devices be placed far from the TV and mobile phone while performing Wi-Fi Direct. - Since the frequency of 2.4GHz has a lot of interference and noisy environment, packet collision will sometimes occur. Even though we have implemented noise-reducing countermeasure to improve the image quality, our TV software could not guarantee that there is no packet loss during transmissions.
- Please try to turn the TV to Off then to On with the remote control to recover.
- Please confirm the permission status on Show Device List / Delete.
If permission is Decline, please delete the registered device from the list and then register it again.
How to delete the registered device
For Android TV models: -
- Press the HOME button on the remote.
- Select Settings.
- Select Network.
- Select Wi-Fi Direct.
- Select Advanced settings.
- Select Show Device List/Delete.
- Select Delete all.
For Other TV models:
NOTE: The steps below use as an example.
For details on operation method, refer to the manual supplied with the product.
- Select Settings.
- Select System Settings.
- Select Set-up.
- Select Network.
- Select Wi-Fi Direct Settings then press the OPTIONS button on the remote.
- Enter Show Device List/Delete then press OPTIONS and select All Delete.
- If there is new TV software available, please download the new software and update the TV.
For how to update, refer to: How to perform a software update.
NOTE: For models other than Android TV released in 2017, refer to the following procedure for performing a software update. -
- Press the Home button on the remote control.
- Select Settings.
- Select Customer Support.
- Select Software Update.
- Select Network.
NOTE: Please try another mobile device or restart the device if the connection is lost or feel unsatisfied with the connection.
