Article ID : 00092651 / Last Modified : 01/05/2020Print
    How to register the Touchpad remote control.
    1. Using the TV remote, press the Home button.
    2. Go to Settings.
    3. Select System Settings.
    4. Select Touchpad Remote Control Setup, then follow the on-screen instructions.
    5. Using the Touchpad Remote Control, press and hold the Volume down key.
    6. Then press the SOCIAL VIEW key for longer than 3 seconds while keeping the Volume down key pressed to register the Touchpad remote control.
