Article ID : 00115618 / Last Modified : 10/02/2026Print
After the power cord (mains lead) is plugged in, it takes time for the power to turn on/it doesn't turn on sometimes/it takes time for the screen and sound to start up.
    After the power cord (mains lead) is plugged in, in order for the system to initialize, the power buttons on the TV and on the remote control might be inoperable for a while, and the Illumination LED might take time to light up.
    This is not a malfunction of the TV or the remote control, so wait about 1 minute before operating.
    NOTE:
    If the Illumination LED is set to Off, the Illumination LED will not light up.
    Follow the steps below to change this setting.
    1. Press the HOME button on the remote.
    2. Select Settings.
    3. Select Illumination LED in the TV category.
