Article ID : 00295242 / Last Modified : 10/02/2026Print
    Wall mounting - compatible Wall-Mount Brackets and screw hole distance measurements for BRAVIA TV (2023 models)
    Please see the following chart and check the compatible Wall-mount Bracket for your TV.
    WARNING! There is a risk of personal injury.
    • For product protection and safety reasons, Sony recommends that the mounting of your TV on the wall is performed by Sony dealers or licensed contractors.
    • For Safety reasons and to ensure a correct installation, please follow the Wall-mount Bracket Operation Instructions, the TV Setup Guide and the following instructions.
    To see the compatibility chart
    • The screw hole distance measurements: Width x Height expressed in mm
      Note: This diagram shows the rear side of a BRAVIA TV.
      Back side of the BRAVIA TV. There is a
      • A: W (width)
      • B: H (height)
      • C: Screw holes
      Notes:
      • In some models of BRAVIA TV, the screw hole distance measurements (W x H) conform to the VESA Mount Standard, but the number and depth of the screw holes do not.
      • Sony cannot guarantee the use of a third party wall mount bracket to mount the BRAVIA TV.
      • For more detailed information and precautions about wall mounting, see the manuals that come with the TV and wall mount bracket.
    • AC Power adapter size: Width x Height x Depth expressed in mm
      An AC Power adapter comes with some models. The diagram shows the AC Power adapter size compatibilities (W x H x D) in the Compatibility chart.
      Ac Power adapter size. The longest part of the adapter is
      • A: W (width)
      • B: H (height)
      • C: D (depth)
    Sony original Wall-Mount Bracket
    Product NameModel NameReference
    Wall-Mount BracketSU-WL450-
    Wall-Mount BracketSU-WL850-
    Wall-Mount BracketSU-WL900
    • Load capacity: 60kg
    • VESA® hole pitch/Screw hole size (W x H) mm: 300 x 300 / 400 x 400
    Compatibility chart
    2023 TV models
    Model NameSeries NameInchesSU-WL450SU-WL850
    • Weight of TV: within 60kg
    • VESA hole pitch/Screw hole size
      (W x H) mm:
    (W x H) mm
    Length of power cord (mains lead)Weight of TV without Stand
    XR-77A95LA95L Series77*1300 x 3003.5 m35.2 kg
    XR-65A95LA95L Series65*1300 x 3003.5 m23.4 kg
    XR-55A95LA95L Series55*1300 x 3001.5 m17.6 kg
    XR-83A84LA80L_A83L_A84L Series83*1-400 x 4002 m42.0 kg
    XR-77A84LA80L_A83L_A84L Series77*1*2300 x 3002 m34.8 kg
    XR-65A84LA80L_A83L_A84L Series65*1*2300 x 3001.5 m23.3 kg
    XR-55A84LA80L_A83L_A84L Series55*1*2300 x 3001.5 m17.9 kg
    XR-77A83LA80L_A83L_A84L Series77*1*2300 x 3002 m34.8 kg
    XR-65A83LA80L_A83L_A84L Series65*1*2300 x 3001.5 m23.3 kg
    XR-55A83LA80L_A83L_A84L Series55*1*2300 x 3001.5 m17.9 kg
    XR-83A80LA80L_A83L_A84L Series83*1-400 x 4002 m42.0 kg
    XR-77A80LA80L_A83L_A84L Series77*1*2300 x 3002 m34.8 kg
    XR-65A80LA80L_A83L_A84L Series65*1*2300 x 3001.5 m23.3 kg
    XR-55A80LA80L_A83L_A84L Series55*1*2300 x 3001.5 m17.9 kg
    XR-85X95LX95L Series85*1-400 x 4001.5 m51.8 kg
    XR-75X95LX95L Series75*1-300 x 3001.5 m42.2 kg
    XR-65X95LX95L Series65*1300 x 3001.5 m32.2 kg
    XR-98X90LX90L Series98---600 x 4002 m67.2 kg
    XR-85X90LX90L Series85*1-400 x 4001.5 m44.5 kg
    XR-75X90LX90L Series75*1*2300 x 3001.5 m35.4 kg
    XR-65X90LX90L Series65*1*2300 x 3001.5 m24.2 kg
    XR-55X90LX90L Series55*1*2300 x 3001.5 m16.9 kg
    KD-75X85LX85L Series75*1*2300 x 3001.5 m34.3 kg
    KD-65X85LX85L Series65*1*2300 x 3001.5 m23.6 kg
    KD-55X85LX85L Series55*1*2300 x 3001.5 m16.3 kg
    KD-85X80LX80L Series85*1-400 x 4001.5 m45.8 kg
    KD-75X80LX80L Series75*1*2300 x 3001.5 m32.2 kg
    KD-65X80LX80L Series65*1*2300 x 3001.5 m21.7 kg
    KD-55X80LX80L Series55*1*2300 x 3001.5 m15.9 kg
    KD-50X80LX80L Series50*1--200 x 2001.5 m12.4 kg
    KD-43X80LX80L Series43*1--200 x 2001.5 m10.1 kg
    KD-75X75WLX75WL Series75*1*2300 x 3001.5 m30.4 kg
    KD-65X75WLX75WL Series65*1*2300 x 3001.5 m20.4 kg
    KD-55X75WLX75WL Series55*1*2300 x 3001.5 m15.3 kg
    KD-50X75WLX75WL Series50*1--200 x 2001.5 m12.1 kg
    KD-43X75WLX75WL Series43*1--200 x 2001.5 m9.3 kg
    • *1 Use of the rear terminal will be limited depending on the wall mounting style. Refer to the Installation instructions (Wall-Mount Bracket) for the TV.
    • *2 Use of the terminals may be limited depending on usage of the TV.
    About the Strength of Walls
    • The wall where the display is attached must have a strength that can withstand 4 times (6 times in some models) the mass of the display. For more details about the required strength of the wall, please refer to the Installation Information (Wall-Mount Bracket) on your TV model page.
    • If the wall strength is insufficient, reinforce it sufficiently. As for the reinforcement of the wall, consult a Sony dealer or a licensed contractor.
    About Screws
    • When attaching the Wall-Mount Bracket to the TV, use screws supplied with the Wall-Mount Bracket. The supplied screws are set with a length of 8 mm to 12 mm from the attachment surface of the Wall-Mount Bracket (thread diameter and screw length are different depending on the Wall-Mount Bracket).
    • If you use substitute items other than the supplied screws, the TV may fall and cause bodily injury to someone or damage to the internal parts of the TV.
    • For details about the screws, refer to the Installation instructions (Wall-Mount Bracket) for the TV or Operating Instructions or Reference Guide for the TV.
