Article ID : 00175521 / Last Modified : 22/05/2025Print
    How to perform a reset or a Factory Data Reset on Sony's Android TV
    IMPORTANT: This solution is applied for Android TVs. For details about how to reset a BRAVIA TV other than an Android TV, refer to How to perform a reset or a Factory Data Reset on a TV (except for an Android TV).
    TV resetting is performed to restore the TV's condition when the TV does not work properly. There are the following resetting methods, which vary in stages depending on the TV's conditions. According to the symptom of your TV, choose the appropriate resetting method.
    1. Step 1 (Power Reset):
      If any issue occurs with the TV operation, first perform a Power Reset below and check whether the issue is resolved.
      How do I perform a (soft) restart (reset) or Power cycle on Sony's Android TV?
    2. Step 2 (Factory Data Reset):
      If the issue is not resolved by the Power Reset of Option A, try a Factory Data Reset.
      IMPORTANT: Be aware that if you perform a factory reset, all of the TV's data and settings (Wi-Fi and wired network setting information, Google account and other login information, Google Play and other installed applications, etc.) will be erased, and the TV will return to how it was at the time of purchase.
      How do I perform a factory reset on Sony's Android TV?
