Article ID : 00199141 / Last Modified : 10/02/2026Print
Which soundbars are supported by the A/V Sync setting on my TV?
List of audio systems supported by the A/V sync setting
    A/V sync-compatible soundbars
    When the A/V sync setting on your TV is set to Auto, A/V sync works with these specific audio systems (connected via HDMI):
    • Bravia Theatre 9 (HT-A9000)
    • Bravia Theatre 8 (HT-A8000)
    • Bravia Theatre Quad (HT-A9M2)
    • HT-A9
    • HT-A7000
    • HT-A5000
    • HT-A3000
    • HT-G700
    • HT-X8500
    • HT-XF9000
    • HT-ZF9
    • TA-AN1000
    How to set A/V Sync to Auto
    Follow the steps below to set A/V sync to Auto:
    1. Open the  Settings screen.
    2. The next steps will depend on your TV menu options:
      • Select Display & Sound → Audio output → Audio system settings → A/V sync → Auto.
      • Select Display & Sound → Audio out → Audio system settings → A/V sync → Auto.
      • Select Display & Sound → Audio output → A/V sync → Auto.
      • Select Sound → A/V sync → Auto.
