Article ID : 00374796 / Last Modified : 28/05/2026Print
    Soundbar or home theater system does not turn on
    If your soundbar or home theater system isn’t powering up, try these steps to resolve the issue.
    Step 1: Check the power cord connection
    • Ensure the power cord is securely connected to an AC outlet or AC adaptor.
    • If the power cord is loose or disconnected, the device may suddenly turn off or not power on at all.
    Step 2: Test the power strip (if in use)
    • If you’re using a power strip (extension cord), unplug the device and connect it directly to an AC outlet.
      • If the device powers on when connected directly, your power strip’s protection circuit may have tripped due to issues like lightning or overvoltage. Replace the power strip and try again.
    Step 3: Verify the AC outlet
    • Plug another device into the same AC outlet to see if it powers on.
      • If other devices don’t work with the outlet, the outlet may be faulty.
      • If other devices work, proceed to the next step.
    Step 4: Wait for the soundbar or home theater system to restart
    • After connecting the power cord to a power strip or AC outlet, wait a few moments for the device to restart. Some devices take time to power on after being reset.
    Step 5: Perform a power reset
    • Unplug the device from the AC outlet for at least 20 minutes. Then, plug it back in and try to power it on.
    Notes:
    • The device’s protection circuit may activate if it detects abnormal voltage (e.g., from lightning strikes or overvoltage). Waiting while the power cord is unplugged may resolve this.
    • To protect your device, follow the power supply voltage guidelines and unplug during expected lightning storms.
    Step 6: Reset to Factory Settings
    • Reset the soundbar, home theater system, subwoofer or rear speaker.
      Note: After resetting, swait a few moments for the device to restart. Some devices take time to power on after being reset.
    Note: A full reset will restore factory settings.
    Step 7: Seek Professional Service
    • If these steps don’t resolve the issue, a professional repair may be required. Consult a repair service for further assistance.
