Applicable Model
This information is for the following model(s):
- HT-A7000
About This Download
Benefits and Improvements
- Adds connection support for the optional BRAVIA Theatre Sub 8 subwoofer
- Adds connection support for the optional BRAVIA Theatre Sub 9 subwoofer
- Adds connection support for the optional BRAVIA Theatre Rear 9 rear speaker
Note: Some models may not be available in certain countries or regions.
Previous Benefits and Improvements
View previous benefits and improvementsFile Info
- Name: Firmware update version 1.812 for HT-A7000
- Version: 1.812
- Size: 607 MB (637 032 878 bytes)
- Release Date: 31-03-2026
Preparation
Check the Firmware Version
Your firmware may already be up to date, especially if you have a new Sound Bar. If the version number is 1.812 or higher, you do not need to update.
If you're not sure, it's easy to check which version of firmware you have:
- Turn on your TV and make sure that it's tuned to the input your Sound Bar is connected to, so if the Sound Bar is connected to the HDMI2 socket, choose HDMI2 as the input.
- Turn on the Sound Bar.
- Press HOME on the remote control and wait until you see the HOME screen.
- On the home screen, select Setup → Advanced Settings with the arrow keys on the remote control and then press ENTER.
- Select System Settings → System Information with the arrow keys on the remote control and then press ENTER.
- On the TV screen, if the version number is 001.812 or higher (the 1st and 2nd zeros of the software version number can be ignored), you already have the most recent firmware version.
Important Notice
- Read the instructions carefully or you may damage your HT-A7000.
- Do not turn off the HT-A7000 or disconnect it from AC power while it is updating.
- Do not press any buttons, except the ones mentioned in the instructions.
- Do not pull out the power cord while the software is downloading and updating. It may cause the system to fail.
Download & Install
There are two ways to update the firmware:
- Updating via the Internet (recommended)
- Update via USB Memory Device and your computer
We recommend this method as it's the simplest way to update. It usually takes about 15–30 minutes. First set up the equipment, then download the update from the Internet.
What You Need:
- an active internet connection (using a wireless router)
- a compatible TV
Set Up the Equipment:
- Turn on your TV and check that the input your Sound Bar is connected to has been selected (So if the Sound Bar is connected to the HDMI2 port, choose HDMI2 as the input).
- Connect the Sound Bar to your internet source using a wireless router.
- On the remote control, press HOME and wait until you see the HOME screen.
Step 1: Install the Update
- At the HOME menu, use the arrow keys on the remote control to select Setup → Advanced Settings → Software Update → Network update, and then press ENTER.
- When the message “Update to a new software version. Never turn off the power while performing the update. Current version 00x.xxx New version 001.812” is displayed on the TV screen, select OK using the remote control and then press ENTER.
- The message “Update Caution” is displayed on the TV screen. Select OK using the remote control and then press ENTER.
- The Sound Bar downloads the firmware data from the Internet.
- After downloading, the Sound Bar restarts, and then the main unit update starts. While the main unit is updating, the update progress status XX% is displayed on the front panel display.
- Once the main unit is updated, the Sound Bar will automatically restart again. If required, the update for the subwoofer or rear speakers then starts.
- The update is complete when the finish message appears on the TV.
Step 2: Confirm That the Update Was Successful
Check the firmware version. If the version number is 1.812, the firmware update was successful.
Troubleshooting
What to do if you have problems updating your Sound Bar firmware using the internet.
- The message “The device is not connected to network. To update, your Sound Bar needs to be connected to the Internet.” is displayed on the TV screen. If you cannot perform the Update via Internet, try the Update via USB Memory procedure.
- Make sure the router and all devices connected between the Sound Bar and the router are switched on.
- Make sure all the cables between the Sound Bar and the router are correctly connected.
- Try the update procedure again.
- After the Update via Internet procedure has started, the message “Download capacity: xxxxxxKB/xxxxxKB and xx% is display in TV screen” is displayed but the progress bar on the display has not changed.
Depending on the network connection, the Update via Internet procedure can take a long time (up to 60 minutes). That is why the message “Download capacity: xxxxxxKB/xxxxxKB and xx% is display in TV screen” is displayed and the progress bar on the display will not change for a long time. - When running the Update via Internet procedure, the TV displays the message, “Connection status cannot be confirmed. Cannot communicate with the server. Please try again later.” and you cannot perform the firmware upgrade.
- Make sure your wireless network is connected.
- Make sure you have confirmed whether or not your Sound Bar has its own IP address in the network settings (If you use a proxy server, type the IP address of the proxy you use into the Proxy Server field instead of the proxy hostname).
- Try the update again.
- The power went off while the update was in progress.
Turn the Sound Bar on and try the update again. - The update has been going on for over 60 minutes and hasn't finished.
If the problem continues, the network transmission speed may be low. In that case, update your system following the Update via USB Memory procedure. - The message “Already Updated” is displayed on the TV screen.
The firmware version currently installed on the Sound Bar is the latest version.
Update via USB Memory Device and Your Computer
We recommend you use the Internet to update if you can. If not, you can use this method instead. You'll download the update to your computer, transfer it to a USB memory device, then transfer it to your HT-A7000.
Preparations for Firmware Update
Before downloading the firmware, please ensure that your computer is running one of the following operating systems and prepare a USB flash drive.
Operating Systems
- Windows 11
- Mac OS X
- Read and agree to the terms and conditions.
- Download the file A7HT-1_812.zip to your computer, making sure to remember the directory.
- Find the file on your computer, right-click it, and click Properties. Check the size is 607 MB (637 032 878 bytes).
Transfer the Files to the USB Storage Device:
- Extract the update file from the A7HT-1_812.zip file.
- For Mac OS X operating system:
- Go to the location where the file was downloaded and double-click the A7HT-1_812.zip file.
- A new file will be created called F_A7HT3.UPG.
- For Microsoft Windows operating system:
- Go to the directory where the file was downloaded and right-click the A7HT-1_812.zip file, and then click Extract All.
Note: For Windows, the default settings for Microsoft Edge will save the file in the Downloads folder. To locate the Downloads folder, click the Desktop tile from the Start screen and then locate the downloaded file using Windows Explorer. - At the Extract Compressed (Zipped) Folders window, click Extract.
- Connect a compatible USB storage device to your computer.
- Transfer the F_A7HT3.UPG file to the USB storage device:
- For Mac OS X operating systems: Drag and drop the F_A7HT3.UPG file to the root folder of the USB device.
- For Windows operating systems:
- Go to the directory where the folder was created, and then right-click the F_A7HT3.UPG file.
- From the menu, click Send To..., and then click the drive that represents your USB device (e.g. Removable Disk E:).
- The F_A7HT3.UPG file will be copied onto your USB device.
- After copying the F_A7HT3.UPG file, remove the USB device from your computer.
Transfer the Update to Your HT-A7000
First, get the equipment ready, then transfer the update to your HT-A7000.
Get the Equipment Ready:
- Turn on your TV and check it is tuned to the input your Sound Bar is connected to. (So if the Sound Bar is connected to the HDMI2 port, choose HDMI2 as the input).
- Insert the USB that contains the F_A7HT3.UPG file.
Transfer the Update:
- At the HOME screen, using the arrow keys on the remote control, select Setup → Advanced Settings → Software Update → USB update, and then press ENTER.
- When the message “Update to a new software version. Never turn off power while performing update. Current version xxx.xxx New version 001.812” is displayed on the TV screen, select OK using the remote control and then press ENTER.
- When the message “Update Caution” is displayed on the TV screen, select OK using the remote control and press ENTER.
- The Sound Bar downloads the firmware data from the USB memory device.
Troubleshooting
What to do if you have problems updating your Sound Bar firmware using your computer and a USB Memory.
- A UPDT and ERROR are displayed alternately on the front panel display.
- Turn off the system and disconnect the AC power cord.
- Turn on the power of the Sound Bar.
- Try the Update via USB Memory procedure again.
Turn on the Sound Bar and follow the Update via USB Memory procedure again. - The A7HT-1_812.zip update file I downloaded from the website cannot be extracted.
Did you download the file successfully? Delete the file and download it again. - The update has been going on for over 60 minutes and hasn't finished.
- Disconnect the AC power cord from the mains, then reconnect it after several minutes.
