Article ID : 00255773 / Last Modified : 07/08/2024Print
How to reset your Sony soundbar or home theater system
    Learn how to reset your soundbar or home theater system.
    Notes:
    • The reset method differs depending on the product.
    • The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may be change.
    HT-A9 / HT-A3000 / HT-A5000 / HT-A7000 / HT-X9000F / HT-XF9000 / HT-Z9F / HT-ZF9
    Select another model
    2. Select SetupAdvanced Settings.
    3. Select Resetting.
    4. Select the menu item you want to reset.
    5. Select Start.
    If you cannot perform resetting using the Home menu:
    • HT-A9: Press and hold the power button on the control box for more than 10 seconds.
    • HT-A3000 / HT-A5000 / HT-7000 / HT-X9000F / HT-XF9000 / HT-Z9F / HT-ZF9: Press and hold the power button and - (volume down) button on the bar speaker for more than 5 seconds.
    If the issue is still not resolved, refer to the product manual or Help Guide.
