Article ID : 00255773 / Last Modified : 26/03/2026Print
How to reset your Sony soundbar or home theater system
    Learn how to reset your soundbar or home theater system.
    Notes:
    • The reset method differs depending on the product.
    • The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may be change.
    HT-CT790 / HT-CT800 / HT-MT500 / HT-ST5000 / HT-ST9 / HT-RT5 / HT-XT2 / HT-XT3 / HT-NT3 / HT-NT5
    Select another model
    2. Select Setup.
    3. Select Resetting.
    4. Select Reset to Factory Default Settings.
    5. Select the menu item you want to reset.
    6. Select Start.
    If the issue is still not resolved, refer to the product manual.
