Article ID : 00255773 / Last Modified : 26/03/2026Print
How to reset your Sony soundbar or home theater system
    Learn how to reset your soundbar or home theater system.
    Notes:
    • The reset method differs depending on the product.
    • The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may be change.
    HT-S20R / HT-S40R
    Select another model
    1. Press the MENU button on the remote control.
    2. Select RESET by pressing the (upper) or (lower) button.
    3. When ALL RESET appears on the front panel display, press the ENTER button, and then the system settings return to the factory default.
    If the issue is still not resolved, refer to the product manual.
