Article ID : 00239863 / Last Modified : 19/01/2026Print
Blu-ray Disc / DVD Player - Component
    Making a Connection
    Connection Diagram of Blu-ray Disc / DVD Player (Component)
    • Component Video cable
    • Composite Audio cable left and right
    TV Set-up
    1. After making a connection, turn on the TV and the connected BD/DVD player.
    2. Press the (Input) button repeatedly to select the input to the connected BD/DVD player.
    3. Start playback on the connected BD/DVD player.
      • If you connect a device that is compatible with “Control for Component,” you can control it by simply using the TV’s remote.
      • If the device has a DVI jack (socket), connect it to the Component (with AUDIO IN) port through a DVI - Component adaptor interface (not supplied), and connect the device’s audio out jacks (sockets) to Component 2 AUDIO IN or Component 3 AUDIO IN. (Jack (socket) name varies depending on your model/ region/ country.)
    Troubleshooting
    Please note that this is just basic troubleshooting based on Sony latest TV models. You can check specific troubleshooting for your model on the i-Manual or operating instructions. If the symptom still persists, please contact Sony.
    No picture appears on the TV screen when connected to the player via Component.
    For some 2014 TV models (i.e. KDL-xxWxxxB Series), there is Problem Diagnosis feature that may detect connected device symptom: Press HOME button on the remote → HelpCustomer Support → Problem Diagnosis: External Device Symptom.
    Please check the following:
    • Is the Component cable connected correctly?
    • Is the Component input selected on TV?
    • If a resolution setting unacceptable to your TV is mistakenly selected, you can reset it to the factory default. In this case, press STOP button on the player for more than 10 seconds to reset the video output resolution to the lowest resolution.
