How to reset your Sony soundbar or home theater system
Learn how to reset your soundbar or home theater system.
Notes:- The reset method differs depending on the product.
- The settings return to their initial status. Settings such as volume, function, sound settings and/or personal information stored on the system may be change.
HT-A9 / HT-A3000 / HT-A5000 / HT-A7000 / HT-X9000F / HT-XF9000 / HT-Z9F / HT-ZF9
Select another model
- Press the HOME button on the remote control.
- Select Setup → Advanced Settings.
- Select Resetting.
- Select the menu item you want to reset.
- Select Start.
If you cannot perform resetting using the Home menu:
- HT-A9: Press and hold the
power button on the control box for more than 10 seconds.
- HT-A3000 / HT-A5000 / HT-7000 / HT-X9000F / HT-XF9000 / HT-Z9F / HT-ZF9: Press and hold the
power button and - (volume down) button on the bar speaker for more than 5 seconds.
If the issue is still not resolved, refer to the product manual or Help Guide.
