Article ID : 00156705 / Last Modified : 16/01/2026Print
How to stop the operation sounds of my computer from being output through the unit
    You can set your computer as follows to prevent operation sounds from being output through the unit.
    For Windows
    • Windows10, Windows 8/8.1
    1. Move the mouse cursor to the bottom left corner of the screen and right-click the Start menu button.
    2. Click Control Panel from the displayed list.
    3. Select Hardware and Sound.
    4. Select Change system sounds.
    5. When the Sound window is displayed, select the Sounds tab, and then set the configuration to No Sounds.
    • Windows7
    1. Select Start.
    2. Select Control Panel.
    3. Select Hardware and Sound .
    For Mac (Mac OS X is used as an example)
    1. Select Start.
    4. SelectChange system sounds.
