Article ID : 00157041 / Last Modified : 16/01/2026Print
    Error codes on BRAVIA Smart TVs (non-Android TV, non-Google TV) when accessing the internet
    Below are solutions for common error codes displayed on Sony Smart TVs (Non-Android, Non-Google).
    Follow the recommended steps for each error code.
    Error code reference table
    Error Code
    Possible cause
    Solution
    1002TV is not connected to the internetCheck the network connection settings and update the TV software.
    1106Error when viewing Internet videos or selecting contentCheck the network status and update the TV software.
    1107
    2123
    3218
    7003
    Network setup issue or unstable internet connectionCheck the connection, restart the network (for example, by unplugging the Wi-Fi router and plugging it back in), and try again after some time. Update the TV software if necessary.
    2200Cannot access the internet or unstable connectionEnsure the internet connection is stable. Restart your network device and try accessing content again
    4012Device failureThe product may require repair. Contact support
    5010Internet processing error during program executionCheck network settings, refresh internet content, update software, or perform a factory reset
    7007Internet connection lost or low speed during the updateUpdate the system software using USB
    7016ISP environment issue (internet service provider issue) during software updateUpdate the system software using USB
    1 to 30
    50 to 200
    300
    Communication issue with the serverRetry access after a brief interval. Update the TV software if the issue persists
    Detailed Solutions
