Article ID : 00274083 / Last Modified : 20/01/2026Print
The Amazon Alexa setup cannot be completed and displays a message that the device is offline
    Follow these steps to add the Home Theater System or Speaker to the Amazon Alexa app again:
    1. Update the Home Theater System or Speaker firmware to the latest version.
    2. In the Amazon Alexa app, select Device → All devices, locate the device displayed as offline, then deregister it.
    3. Use the Sony | Music Center app to again set up the Home Theater System or Speaker with Amazon Alexa:
      1. Connect the Home Theater System or Speaker to the same Wi-Fi network as your smartphone.
      2. Open the Sony | Music Center app, select Speaker & Group, and select the device.
      3. Select Settings → Amazon Alexa → Setup, and then follow the on-screen instructions to complete the Amazon Alexa setup.
    Note: This procedure is confirmed as of December 2021. For the latest information, refer to the Help Guide or application support page.
