In order to remove speakers, other audio devices or groups from the Music Center (SongPal) app, follow the below procedure:
- In the Speaker & Group screen, tap the drop-down menu icon in the top-right corner of the screen
- Then, select Remove Speakers
- Finally, place a tick next to the speakers you wish to remove, and tap REMOVE
- Press OK to remove the audio device or group.
